big power 4x4 engine and other parts 3/1/09
basically selling everything of my resto thread here
https://passionford.com/forum/restorations-rebuilds-and-projects/157130-e5-mds-4x4-saph-re-build-for-sale.html
serious offers please
turbo technics anti roll bar / compression strut set up with new rose joints/bolts/shims, proper bit of kit! extremely rare now. all powdercoated - £offers
powder coated front hubs with new bearings £90
same as this just to show you!
front & rear new grooved disks and red stuff pads for rear cost 250 - £170
engine- 200 block, 10 long mountune studs, 8.6-1 cr, mahle pistons, new mains big ends little ends rings valve guides checked etc etc, lightened+balanced crank and flywheel/alcon 6 paddle clutch, cometic multi layer head gasket, ported 4x4 head, isky valve springs, custom cams, new high pressure oil pump, new quaife verniers properly timed, m8 engine mounts, with rite parts engine will do 550bhp 500lbs trq. fresh engine not even been run since build. £offers around 4k
'mint' mongoose as new all polished up £300
brand new speedo cable
mins carpet
new alternator £50
re con starter £40
polished grp a 044 pump + new filter + lots of aeroquip! £?
brand new fuel tank with aeroquip fittings welded and smoothed in ready to paint to match the fuel pump £??
electric sunroof kit £65 *prov sold*
new ford water pump with threaded fitting for hose never been near water!comes with cometic gasket £85
power steering pump
powder coated water pump pulley £10
new diff brackets £15
sapphire/escort top mounts £50
crank sensor £20 covered no more than 2000 miles!
4x4 fuel rail complete with as new fuel reg. fitted up with nylon pipe and a push fitting from the reg to the plenum and a take off for a fuel pressure sensor (can be blanked off) painted in chrome affect paint. all fittings brazed onto rail so no leaks what so ever!!also comes with brand new injector clips £45
powder coated rear beam brackets and new allen key bolts £15
gearbox spacer £40
2x new mounting bolts and rubbers £10
lower bumper trim *new* on the corner somethings been sat on it so when fitting it it just wants an extra screw putting in to pull it back
powdercoated alternator bracket £offers
absolutely mint raven dash with all trims and lower dash etc if needed
rs gear knob
second hand set of mats
brand new set of proper ford mats -rare! il have to get pics-
2 new headlights
smoothed and polished engine mount arms and oil filter arm
mint crossmember
VERY good doghnut with or without prop, all painted up and laquered no play at all
mint sill trims and kick panels with lights
mint grill in x power grey!
stick on stainless sill trims
new door rubbing strips 2 missing getting extremely rare now!!
mins carpet
new alternator £50
re con starter £40
power steering pump
gearbox spacer £40
rs gear knob
2 new headlights
mint crossmember
