Saph cos 2wd ABS
Hi all. I've got the standard 2wd abs and assisted servo on the saph, standard 4pots and solid rear discs.
when i bought it and used to brake the pedal felt nice and hard but it used to 'click' or 'notch' down really quite annoyingly... i un plugged the abs block under the battery and the clicking stopped but the pedal doesn't feel anywhere near as good.
is the notching normal? i guess not. have i a problem?
Its off the road at the moment and while its parked up its one of the things i want to sort.
cheers ian
cheers ian
Russ Payne
Sep 25, 2015 08:29 PM
