Can I weld the wastgate shut for an ext one?
Old Jul 23, 2008 | 12:35 PM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
Default Can I weld the wastgate shut for an ext one?
as above, really fance having a screamer pipe on my car, I know its a bit boyracer but the noise is awsome of them. I dont want to mess about sourcing a new turbo as mine has only dome 2k and is a stage 3. Can I simply weld the wastgate shut, bin the actuator and install an external wastgate in the carrier???
(please dont take the piss out of me.lol)
Old Jul 23, 2008 | 12:45 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Technically yes, but it's not a great idea.
Old Jul 23, 2008 | 12:46 PM
Raj B's Avatar
Raj B
lol sad i know, why would it be a bad idea though? I though external wastgate allowed mroe control over boost pressures?
Old Jul 23, 2008 | 12:49 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It's not just the fact you have an external gate (if used incorrectly or the wrong spec, you can have worse boost control).. but a turbo without integral wastegate flows differently.. which you wont have.
Old Jul 23, 2008 | 12:51 PM
Raj B's Avatar
Raj B
ahhh, well there goes that idea, thank mate
Old Jul 23, 2008 | 05:00 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
can be done, seen an xr2 reach 240bhp on the rollers using a cossie t34 with wastegate welded shut and external wastegate coming off the manifold.
Old Jul 23, 2008 | 07:43 PM
crazycage's Avatar
crazycage
thats a big turbo to just make 240bhp tho
Old Jul 24, 2008 | 06:31 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
that's what I was thinking
Old Jul 24, 2008 | 09:04 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
was at 23psi though, thread here:
http://xrtwo.speedcentral.co.uk/view...0861&start=750
on an r5 carb too.
turbo pictured isn't the one used for the RR'd session.
Old Jul 24, 2008 | 09:24 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
23 psi on that turbo on a zetec would be more like 330bhp
Old Jul 29, 2008 | 06:01 PM
steven botes's Avatar
steven botes
my t34 has had the internal gate welded , and i have an external turbonetics evolution fitted to the manifold , with a so called screamer pipe fitted. it wastes to a 25mm pipe which exits right next to the turbo downpipe on the bend before the sump
sounds awesome at high boost (1.5bar) , but would be a bastard for everday use , plus i have a dump valve fitted which makes long trips a headache
fitting switchable boost to this setup is easier though , and i doubt the standard internal gate would work with my sized turbo , the port is tiny and would probably give serious creep
my xr3 is a drag toy only though , so i can live with it
Old Jul 29, 2008 | 06:18 PM
Raj B's Avatar
Raj B
with a screamer pipe is it really loud all the time or just when you are on boost? if it is safe to weld the gate shut them im dying to have a go, would make the car a little unique and stand out from the crowd. I love the noise of wastgate chatter but that isnt good for the turbo so im stuck with the dump valve at the mo. Every man and his dog has one.lol
Old Jul 29, 2008 | 07:32 PM
steven botes
horribly so , the yanks call it a screamer pipe for good reason!!! , only screams when it waste on boost
Old Jul 29, 2008 | 09:55 PM
Raj B's Avatar
Raj B
so if you ar ploding around town of boost is it relativle quiete? is the external wastgatelocated in the charge carrier??
Old Jul 31, 2008 | 04:23 PM
steven botes
dont understand the question , but off boost it is quite to a point , cept i have a 63mm front to back xuast with a single backbox , so its noisy all the time
Old Jul 31, 2008 | 06:02 PM
Turbocabbie
Top Cab !!
if you use a screamer pipe on the roads in the UK you should expect to get nicked pretty quickly
Old Jul 31, 2008 | 08:33 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Screamer Pipe sucks. Mine has its own exhaust with a silencer in it.
Old Aug 3, 2008 | 07:42 PM
steven botes
im a reservist in the South African Police(work for free part time) so i always have my police id on me , saves me major headaches while driving my car
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
