focus speedo
Old Jul 22, 2008 | 09:14 AM
rach123's Avatar
rach123
Default focus speedo
my speedo is out by about 10mph from 0. does anyone no how to fix it?
Old Aug 9, 2008 | 08:46 PM
pdfbt40's Avatar
pdfbt40
Is it out against the Focus's digital reading in diagnostics mode? All the analogue readouts seem to have the needle put on ~5mph above the actual internal reading from the PCM.
If you want it more accurate pull off the needle and reposition it, though that is a bit difficult as your driving.
If the digital reading is out then there are 2 choices.
1) Get a Ford dealer to recalibrate the PCM, although I believe this is done in terms of wheel and tyre size. Or,
2) For less money, buy a SpeedoHealer and install it in the VSS line to the PCM. That can recalibrate the signal to whatever you want, well almost. Its what I've used to recalibrate a MT285 box for use on a standard Focus.
Martin
cossie brad
Sep 29, 2015 02:38 PM
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
