fiesta xr2i bottom end...
Old Jul 21, 2008 | 09:18 AM
wiser's Avatar
wiser
Default fiesta xr2i bottom end...
ive been told that the bottom end has gone on my 1990 8v xr2i...someone said to replace i dont have to use another xr2i bottom end, and i could use one from either a rs turbo or 1800....is this right????? thanks
Old Jul 21, 2008 | 10:13 PM
rapidonion's Avatar
rapidonion
Default block
1.8 cvh needs a bit of work and can be expensive the rs block could be used but uses low comp pistons so itll be slow and boggy go zvh use the 1.8 block there cheap as and fairly easy to do and youll end up with a better engine for less money or just put either a 1.8 or 2.0 zetec in out of a mondeo again its not rocket science and the rewards are there to be had.
cheers mike
Old Jul 22, 2008 | 07:06 PM
redrsmk5's Avatar
redrsmk5
really so much easier to use another xr2i bottom end. As said by rapidonion the turbo blocks pistons wont help and the 1800 will need funds to make work.
if it were me it'd be same again.
Old Jul 22, 2008 | 07:12 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
yea xr2i bottom end is the eayest way to get back on the road and cheepest have you considered the zvh conversion? its an easyish 400cc gain
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
