s1 cold starting advice
my s1
only recently aquired, only just learnt the knack but cold startings a pain
if turn key it will fire not quite idle and die and a pain to restart
if i just touch the throttle a inch or so and turn the key it fires within a second or so but i have to keep the revs up for a good minute or so before it will think iif idling etc, if i dont get it rght and it stalls its a pain to restart, if i get out touch the flap on the metering unit down a few mill and get someone to turn key it fires straight away
but as i say i know the car and can now start it perfectly, but i want it to fire and idle on the key not mess about for a good minute or so
any advice?
any advice?
On a K- and KE-Jetronic you always should open the throttle to ~50% when starting.
Idling... check the additional air unit (don't know how you call it), fuel pressure and the temperature sensors...
ned to get the car checked over fella
i remember the servo was weeping slightly
is the cold start still disconnected
also check that the auxirly (spelling) is opening and closing correctly
whats does the car idle on when warm using a proper rpm gauge not the rev counter
also started and come on choke evertime when i had it fella propb needs a good set up and clean
havent checked anything yet, not ormally a problem i just plug them into the diag machine but cant with this old thing
just a few pointers would help, were is the cold start sensor etc
gup auxillery?
gup auxillery?
bit of a pain being on the under side of the inlet manifold..but youll sort it..i was ok i done it in work on a ramp...
but yeh mine was an arse to start when the sensor went down..they are only cheap as well..get on it mate
went to scrappy doday and got all the indicator wiring etc sorted
looked under inlet manifold, saw a few plugs but there was a black plug underneit at back, unplugged it started car it stared and idled perfectly
dont really want to leave it unlplugged so ill get a new sensor
thats black plug is for the idle and cold start idle fella you can cleans these out
better off leaving it plugged in as when it gets warm it will idle all over the place is the blue plug still disconnected under the inlet
couldnt see one unplugged but then hard to see anything, ill bung the car on ramp in next few days and have a look.
i did see a cylindrical unit under manifold wth a plug i presumed that was the idle control valve, it wasnt that one i unplugged
why is whatever plug your n about unplugged?
lee
lee
the blue one that i unplugged was the cold start one
never needed it as the car would flood in the morning but once unplugged it would start and idle almost on the button without the throttle
heres the thing, the plugs i saw looked brand spanking new, metal spring depressed to pull unclip, wiring all nicely taped
prob wrong but maybe its had a touch of rewiring since you had it, all looks good, or maybe there is a black plug like that? if stood drivers wing looking down back of manifold thats were i saw it and unplugged
does sound like my work
put the car on the ramp fella and you can c all the plugs properly fella
well i had to pop into the workshop a min ago to pick up my dash gear as a m8 needed a last minute job, thought id turn the key and see, no throttle it started and idled
so spose unplugging whatever i did sorted it, however i will reserve jugement till seen it hot and ive checked the co reading
unplugging things doesnt fix faults, it bodges them. just get it into any half decent RS Turbo specialist, it probably needs setting up so it dont blow anyway
i must of een colour blind yesterday it was the blue plug i unplugged gup
mopped the whole car today, cleaned it all shes looking quite nice
as soon as i get it back hom ill take some pics for ya mr broadside
