misfire at 15psi??
Old Jul 19, 2008 | 07:49 PM
picky775's Avatar
picky775
Default misfire at 15psi??
Getting a missfire at 15psi boost could it be a fooked cam?? or something worse?? was getting mapped at the time so fuel,timing etc were ok??? Also the head is quit tappety 1.6 cvh by the way.
Old Jul 19, 2008 | 07:50 PM
RWD Pete's Avatar
RWD Pete
sound lika a machine gun when it misses?
Old Jul 19, 2008 | 07:54 PM
picky775's Avatar
picky775
Its like overboost but its not that as im runnin gotech.
Old Jul 19, 2008 | 07:58 PM
RWD Pete's Avatar
RWD Pete
usually ignition when on boost, from my experiance sounds like a machine gun going off
Old Jul 19, 2008 | 09:23 PM
gup's Avatar
gup
check your plug gaps
my old s1 would misfire on boost as the gaps where a tad bit to big
Old Jul 19, 2008 | 09:30 PM
Rick's Avatar
Rick
As a little bit of a side note, the car will not idle any leaner than 12:1. My diagnosis is th cam.
Old Jul 19, 2008 | 10:18 PM
picky775's Avatar
picky775
If weather is good tomorrow i will get the cam out and send you some pics of it Rick,just hope it is the cam and nothing to serious.
GUP.. put new plugs in it today and still no joy
Old Jul 19, 2008 | 10:20 PM
gup's Avatar
gup
did you make the gaps smaller tho
what gap setting are thier
Old Jul 19, 2008 | 10:24 PM
picky775's Avatar
picky775
The gaps are fine mate,RICK is mapping the car for me and he thinks it could be cam problems as the head is quit rattly aswell so goin to check that tomorrow depending on weather.Maybe needing a new cam and followers if anyone has got any??
j.hammond1
30
Oct 31, 2021 05:28 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
jay030787
Aug 17, 2015 06:16 PM
taylora1409
Aug 12, 2015 12:06 PM
