Need wiring diagrams
Old Nov 2, 2004 | 07:54 PM
K17SSE's Avatar
K17SSE
Default Need wiring diagrams
I have a problem with my small turbo cossie
The fuel pump relay keeps dropping out due to a lack of voltage on the trip side.
so basically the car stalls and will not start unless you bypass the relay.
I Have fitted an external relay and all is fine but i want to trace the wires and check for any shorts or damage
So has anyone got a diagram for the EECIV cossie , i brought a cd ofebay and i only has the normalcossie diagrams
CHEERS
PAULCR
Old Nov 3, 2004 | 10:40 PM
AJ Escos's Avatar
AJ Escos
have you checked the problem isnt within the fuse box as these are a known problem point with the escos
Old Nov 5, 2004 | 04:07 PM
K17SSE's Avatar
K17SSE
hi mate
yes i havr tried a fusebox but the problem is still there!!!
Its that there is not enough voltage to keep the relay latched
cheers anyway
PAULCR
Old Nov 5, 2004 | 09:59 PM
AJ Escos's Avatar
AJ Escos
is it chipped m8
Old Nov 6, 2004 | 01:21 PM
K17SSE's Avatar
K17SSE
No not yet mate
in the future if i can get it running right
Old Nov 8, 2004 | 11:30 AM
GMRJJEscos's Avatar
GMRJJEscos
Hi Paul, have you had any luck getting a wiring diagram yet, I'm having a very similar problem at the moment, I know it's a wire, but I just don't know which one or where
Old Nov 11, 2004 | 07:55 AM
Baby blå's Avatar
Baby blå
Hello guys
Is it the wiring diagram over engine loom/management you need ??
Just the Weber/Marelli part??
// M
Old Nov 11, 2004 | 11:11 AM
GMRJJEscos's Avatar
GMRJJEscos
I could do with the wiring diagrams for the whole car, but at the moment, anything is better than nothing
Old Nov 11, 2004 | 02:08 PM
Baby blå's Avatar
Baby blå
Ok, can you give me a fax number ??
Ifyou dont wanna leave it here, just send a pm
I will send this tomorrow. Going home from work now.
Se ya
Old Nov 11, 2004 | 05:54 PM
DazC's Avatar
DazC
Weber Marrelli diagrams won't help when the car runs on EEC4.......
Old Nov 12, 2004 | 07:57 AM
Baby blå's Avatar
Baby blå
K17SSE is running EEC IV but the other guy is not.
Not according to his avatar
But there is no problem, i got em both.
The bad thing is that thay are in Swedish.
Let me know if you need it
Old Nov 12, 2004 | 08:53 AM
DazC's Avatar
DazC
I think it would be best for them to identify which diagram they each require!
Old Nov 12, 2004 | 08:55 AM
Baby blå's Avatar
Baby blå
I´m waiting
Old Nov 12, 2004 | 12:36 PM
K17SSE's Avatar
K17SSE
hi
sorry for the delay
I need the diagrams for the ignition, fueling, and engine loom to fuse box
Any would be great as long as it is for the eeciv
If the colors are labeled in swedish could u translate them
I have see the ones for weber etc and they seem simple to follow as long as you have the key for the colors
My fax is 07967096905
Thanks very much this will give me a job to do in the winter
PAulCR
Old Nov 12, 2004 | 12:55 PM
Baby blå's Avatar
Baby blå
Up and avaaaay
The wiring colours are in english.
Let me know if you need something else or translation.
its weekend soon
Old Feb 23, 2005 | 07:21 PM
whitneyd's Avatar
whitneyd
Would you fax this to me in Italy? If so my fax number is 0039-0434304050.
ATTN: David Whitney
Thanks
Old Feb 26, 2005 | 08:31 AM
july1's Avatar
july1
I don't have any diagrams for the T25 but what I can tell you is that wiring is almost identical on many injection cars (including the T35) the FP relay is directly driven by the ECU but the signal also passes through an inertia switch (in case of crash the FP is stopped!)
You should first check this switch!
On the LHD T35 it's located behind the foot panel on the passenger side (i.e. on the right) behind a little plastic cap. The switch is just under the ECU (its a little black plastic box with a little red push button on top)
I guess you will also find the location described in the driver’s manual.
You should try to reset it and if no improvements check the tension in this area.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
THE RADMAN
Sep 19, 2015 12:57 PM
