cosworth ISCV
Old Jul 18, 2008 | 09:20 PM
s1 2oobhp's Avatar
s1 2oobhp
Default cosworth ISCV
hi does any one know what way the + - is on the idle valve speed sensor 4x4 cosworth or a pic of the connector loom
cheers
Old Jul 19, 2008 | 07:33 AM
Just use a tester to determine, it is a std amp connector.
Old Jul 19, 2008 | 07:44 AM
s1 2oobhp's Avatar
s1 2oobhp
cheers tabetha the only problem is that im fiting a gotech ecu loom to a zetec turbo an using a cosworth throttle body so i dont have a cosworth loom to check an theres no markings on the iscv
cheers
Old Jul 19, 2008 | 06:04 PM
You DON'T actually need a ISCV, with a decent ecu, as timing will be altered to alter idle speed at all temps, I'm removing mine when it goes to mapper.
Old May 13, 2011 | 01:49 PM
Drupi's Avatar
Drupi
+ left side
- right side
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
RSmark84
Sep 13, 2015 01:29 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
