escort gti poor idle running
Old Jul 18, 2008 | 07:26 PM
Trist's Avatar
Trist
Default escort gti poor idle running
My sister has a 1997 escort GTI nad its been running lumpy and missfireing, or "juddery" then clears and is fine for a bit.
she is doing part time in a garage to get to the the ins and outs of cars, they have changed oil/filter, fuel filter, plugs, leads, been on fault diags and brings up no fault codes,
any ideas
many thanks
Old Jul 18, 2008 | 09:11 PM
JamesH's Avatar
JamesH
Throttle position sensor?
Old Jul 18, 2008 | 09:21 PM
Trist's Avatar
Trist
will tell them to check it thanks. Is it right that you can tell if its ok by moving the throttle by hand and if TPS clicks just as throttle is moved its ok??
Old Jul 18, 2008 | 09:24 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Only thing I can think of is an air leak, but that would normally show up as a lean mixture on the fault codes.
If you want to try the substituting the TPS I've got a good used one here, the number on it is 95BF 98989. You can have it for whatever it costs to post.
However, I suspect if it was the TPS it would come up with a fault code.
Old Jul 18, 2008 | 09:31 PM
JamesH's Avatar
JamesH
Air leak/TPS/ISCV... list is pretty endless unfortunetly
Old Jul 19, 2008 | 07:52 AM
Trist's Avatar
Trist
Leeeroy- very generouse offer thanks mate, if they want to try that I will get hold of you thanks.
going to tell them to put diags machine on again and look properly??
Old Jul 19, 2008 | 07:59 AM
BM08's Avatar
BM08
if its anything to do with idling then id go with the TPS.
when i had a GTi it was hunting, and it would idle at 2-3k, i changed the ISCV and it didnt make a difference, replaced the TPS and i didnt have any more probs for the following year.
I know its not your EXACT description but still to do with idling.
Old Jul 19, 2008 | 08:02 AM
Trist's Avatar
Trist
worth a try cheers.
Old Jul 19, 2008 | 08:42 AM
EssexMikeSi's Avatar
EssexMikeSi
I'd say tps aswell unless the ICV hasnt been changed either. Zetec engined escorts are a fooking nightmare for idle issues. Ive not had one mk6 out of about 7 that hasnt had some sort of idle issue at some point in its life. And it seems once u get it, its very hard to get rid of no matter how many parts u replace in my experience.
Old Jul 19, 2008 | 02:58 PM
Trist's Avatar
Trist
she took it to auto electrition and result is faulty ECU... any one got one?
Old Jul 20, 2008 | 10:19 AM
Wardy257's Avatar
Wardy257
A fualty ECU is very rare, they do go wrong but rarely. Are you sure you trust this autoelectrician?
I would clean the inside of the ISCV with some carb cleaner and also make sure the electrical connection to the ISCV is clean. That will probably sort it.
Old Oct 10, 2010 | 03:26 PM
tezkez's Avatar
tezkez
Default escort gti idle lumpy
Hi can anybody help my escort gti has just started running lumpy on idle i have changed the plugs but dony know what to do next.......
Vincereese
Jun 1, 2023 09:14 AM
mrice0107
Aug 21, 2015 07:55 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
