Battery trouble
Old Jul 16, 2008 | 04:00 PM
robj20's Avatar
robj20
Default Battery trouble
The battery light has stopped coming on when i turn the key and if the car runs the alternator is not charging, the alternator is working as its brand new and had another regulator fitted as well. I managed to get it working the other day by changing the spade connector on the blue wire for the alternator and it worked once, now its stopped again. Any ideas?
Old Jul 17, 2008 | 03:38 PM
robj20's Avatar
robj20
I have heard that you can put a live to the connector and the alt will work is this right?
So i can put a wire from the battery to the connector where the blue wire is.
Old Jul 17, 2008 | 05:15 PM
rs_turbo_ant's Avatar
rs_turbo_ant
try checking you battery light bulb....happend to me got new battery alternator and all it was was the bulb in the dash not in properly so give that a go
Old Jul 17, 2008 | 05:24 PM
rst230bhp's Avatar
rst230bhp
hi mate
Try earthing the blue wire at the alternator does the light come on if it doesnt then there is a break in the wire sumwhere.
Old Jul 17, 2008 | 06:35 PM
RobL's Avatar
RobL
ive had same problem today,missed my mot again because half a mile down the road the battery was completely flat
no battery light coming on on my dash either, im thinking thats the cause because ive just put these clocks in and ive not used it since theyve been in
did seem to drain awfully quick though and the battery was fully charged.
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
