v tight plugs
Old Jul 16, 2008 | 03:48 PM
dreamin's Avatar
dreamin
Default v tight plugs
in the process of changin spark plugs over today (engine was cold) changed 1st 2 no probs but cannot for the life of me get the 3rd n 4th undone (crossover pipe aint helpin) but why would they be sooooo fukin tight in the 1st place ??
anything i can try as i dont wanna go to heavy handed n get the old plugs snapped n stuck in there
Old Jul 16, 2008 | 03:51 PM
Mark RS's Avatar
Mark RS
try run the engine to heat them up and romove the cross over pipe
Old Jul 16, 2008 | 03:53 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Short of trying hard with a longer ratchet handle or t-bar, which is likely to break things, I'd throw some WD40 or something like that down the hole, and leave it to soak in for 24 hours or so, keep topping up.
Hopefully it will get through whatever is holding the plug in place
Not sure if warming the engine up would help or hinder though
Old Jul 16, 2008 | 03:59 PM
dreamin's Avatar
dreamin
tried with the engine warm b4 n could budge any of em , think the heat caused them to expand!!
think ill get some gt85 (wd40) on em see if that helps ,
will let u know how it goes!!
Old Jul 16, 2008 | 04:15 PM
frog's Avatar
frog
Take your time with it and let it soak in for several hours, add some from time to time, but really give it some time to work. Most of the time, we try too soon and the fluid hasn't had a chance to work properly.
It certainly helped with the crankshaft pulley on my cossie.
Old Jul 16, 2008 | 04:27 PM
DanCossie's Avatar
DanCossie
Post Whore
WD40 overnight wll release them.
you sure you turning the ratchet the rigth way
Old Jul 16, 2008 | 04:32 PM
dreamin's Avatar
dreamin
lol, dan give me a little credit !! haha, i know ur used to dealin with tight plugs more than me but think i know wot way to turn a nut pmsl
Old Jul 16, 2008 | 04:57 PM
kjc300's Avatar
kjc300
Just in case.........
Lefty Loosey. Righty Tighty!!!!
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
