Focus 1.8 Zetec Cutting Out
Old Jul 13, 2008 | 02:44 PM
JK99's Avatar
JK99
Default Focus 1.8 Zetec Cutting Out
A pal of mine has a 2001 Focus Focus 1.8 Zetec and lately it has developed a problem with cutting out at random times while driving.
He says it doing it when going into junctions or turning corners so i'm guessing it's happening when the clutch is in.
My thoughts were along the line of an air leak on the inlet side, maybe the gasket, but i'm no mechanic.
He's had it on the computer and no faults were detected.
Any ideas guys?
Joel
Old Jul 13, 2008 | 02:49 PM
pani_k's Avatar
pani_k
PassionFORD Member
Common problem when coming up to junctions/stopping is the ISCV (idle speed control valve mate). This won't show up on computer and it's most probably this. It's located on the inlet side on the throttle body area/section I think and is accessed from underneath the car. You can take it off, give it a bit of a clean with brake cleaner, and if you can, I've been told try to lubricate it as well to stop it drying out, with what exactly though I don't know, perhaps WD40 or spray (white) grease at a guess. It's also best to order a new gasket for it as well. About Ł6 delivered or a few quid if you can pop down your local Ford parts dept.
Old Jul 13, 2008 | 03:02 PM
fonfe's Avatar
fonfe
also check the manifold breather pipe hasnt split in the kink as ive seen that happen before and it cause it tostall randomly
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Dubs44
Aug 21, 2015 02:42 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
taylora1409
Aug 12, 2015 12:06 PM
gingerturbo
Aug 11, 2015 09:44 PM
