Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
difference in head from a crossflow
Old Jul 13, 2008 | 02:16 PM
RoyP's Avatar
RoyP
Default difference in head from a crossflow
hi all.
i have here 2 heads, 1 from an 1300 and 1 from a 1600 blok, the valves have the same size but one has a chamber in the head, what is the difference between these? and wich one would be better the mount on a 1600 blok? or is there no difference?
if i would flow this head would that give noticeble more power?
many thanks
Old Jul 13, 2008 | 02:20 PM
graham c's Avatar
graham c
not sure but i no the 1300 pistons are better in the 1600 high compression
Old Jul 13, 2008 | 02:22 PM
RoyP's Avatar
RoyP
i already have 1300 piston in it
Old Jul 13, 2008 | 10:42 PM
groomers's Avatar
groomers
you would need the flat head else your compression will be way too low
Old Aug 10, 2008 | 09:54 PM
dxcgnoc's Avatar
dxcgnoc
The chambered head is from the early crossflow 681f block and the flat head is from later 711m block .
What size are the valves on the chambered head
Old Aug 11, 2008 | 01:24 PM
RoyP's Avatar
RoyP
hi
valves are 31 ex, and 38 in
Old Aug 14, 2008 | 04:19 PM
Senuwees's Avatar
Senuwees
ive also got a 1300 head at home but it doesnt have the chamber innit, i just heard that the valves are smaller!
Old Aug 17, 2008 | 06:41 PM
l0ubie's Avatar
l0ubie
keepin' it ol' skool
the top head is a standard stage 1 1300 head with those valve sizes.
a 1600 should have 39.5 in and 34 ex,
so they are both 1300 if they are both the same size!
i would use the chambered head if i were you AS LONG AS your running flat top pistons!!
otherwise your compression ratio drops!
http://rcma.free.fr/escort/ford_kent_crossflow.pdf
there is some more info!!
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
pie-face
Sep 15, 2015 10:43 AM
CrOwSoN15
Sep 14, 2015 11:33 AM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
