Getting petrol out of my engine
Old Jul 9, 2008 | 07:29 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default Getting petrol out of my engine
had problem with my metering unit, i have changed it now, how do i take any fuel out of system as i think may have flooded it when tryin to get it started last time n e help would be gratefully appreciated
Old Jul 9, 2008 | 07:42 PM
Adam.'s Avatar
Adam.
please
Old Jul 9, 2008 | 07:43 PM
C4llyT's Avatar
C4llyT
Turn it over with plugs out??
Old Jul 9, 2008 | 07:47 PM
Adam.'s Avatar
Adam.
isnt that to get oil around the engine
Old Jul 9, 2008 | 07:49 PM
C4llyT's Avatar
C4llyT
Is a lot of work compared to pulling a fuse or removing coil lead etc, but would do that too.
Adam.'s Avatar
Adam.
anything else?
Old Jul 9, 2008 | 07:50 PM
bud-weis's Avatar
bud-weis
Football Cwazy
start it up, burn of excess fuel....then do an oil change to be sure it's nice and fresh.
Old Jul 9, 2008 | 07:52 PM
Adam.'s Avatar
Adam.
yes but i think its not starting because its full of fuel
Old Jul 9, 2008 | 07:53 PM
C4llyT's Avatar
C4llyT
Either do as I suggested, or pull fuel pump fuse and crank it for a while.
Old Jul 9, 2008 | 07:55 PM
Adam.'s Avatar
Adam.
could i lift the backseat up and disconnect the fuel pump, then take the plugs out and turn it over? and it should drain it all out?
Old Jul 9, 2008 | 08:01 PM
C4llyT's Avatar
C4llyT
Yeah could do mate, don't want to do it an easy way by sounds of it so that would be ideal.
You could remove the engine, strip engine and remove pistons, and petrol would drain out, then simply refit.
Old Jul 9, 2008 | 08:04 PM
Adam.'s Avatar
Adam.
lol smartass, just thought it would be asier to disconnect under the seat as i have a modified erst wiring loom so my fuse box is tucked behind the dash (not down by drivers footwell)
Old Jul 10, 2008 | 02:10 PM
C4llyT's Avatar
C4llyT
Do what you like, won't listen to anyone so no point asking really.
Old Jul 10, 2008 | 02:16 PM
andy130's Avatar
andy130
take out th sprak plugs and get a pipe put it in hole pump th petrol out mate if thats any good ul get sme out anyway
Old Jul 10, 2008 | 03:48 PM
cossiegreg1's Avatar
cossiegreg1
leave for an hour then try and start it. i would personally take plugs out and check them.
once you get it running then change the oil.
Old Jul 10, 2008 | 07:52 PM
Adam.'s Avatar
Adam.
how bout u take ur head out your ass
Old Jul 10, 2008 | 08:01 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Take plugs out and turn over.
Old Jul 10, 2008 | 08:31 PM
C4llyT's Avatar
C4llyT
Check first and last suggestions TRYING TO HELP YOU in this thread....
Both the same, so should have just taken the advice to start with.
Old Jul 10, 2008 | 08:36 PM
rst in breaking's Avatar
rst in breaking
as said mate, plugs out and turn over, if its flooded it will spit the excess out
RB26DETT
Oct 25, 2015 05:41 PM
Sheepdisease
Aug 30, 2015 09:11 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
