ST FOCUS
Reading Fast Ford This Month, It Has Buying Guide For St Focus...
It Tells You About The Engine If It Has Got A High-pitched Shrieking Noise And
A Vacuum At Idle That Sucks A Removed Dipstick Back Into The Block Points To
The Failure Of The Oil Separator Diaphragm!!!
My Car Is Doing High-pitched Shrieking Noise, Went To Ford And Asked About This
Part Called "" The Oil Separator Diaphragm"" Hadn't A Clue What I Was Talking
About.. Can Any One Help With A Part Number??
Thanks..
Thanks..
do a search it's been covered before, you need a oil filter housing, about £100 on back order for ages iirc. if your ford dealer get arsey tell them to call ford technical as there will be a broadcast message any day regarding the fault.
wowk
Mar 30, 2021 07:49 PM
