Who does adjustable rear beams for cossies ?
If you go Adrenaline, do NOT go for the tubular one, as the arms have clearance issues and foul the bodywork necessitating severe chassis mods
The Ahmed one is Ł1k (exchange) and is adjustable for both toe and camber.
.The Ahmed one is Ł1k (exchange) and is adjustable for both toe and camber.
Design flaw ? or just something that came about after they were produced ?
how much moddification is needed to make sure the arms dont foul
On the one I adjusted though it did NOT have actually enough adjustment available IMHO, I wasnt actually able to quite get the toe to where I wanted without having to dial in slightly more camber than I wanted, not sure if thats specific to how its fitted on that car in question, or if thats always the case.
But as a result I would have reservations about buying one personally based on what I saw, especially when coupled with the required chassis mods that Mike mentions, where as the ahmed one has been proven time and time again and I believe is a straight fit.
Im sure that there was nothing up with the Adrenalin one that couldnt be fixed though, so dont think im slagging it off as useless as im not, but essentially it still requires a small amount of development work IMHO (especially regards to fitting ease from what Mike said)
.I'm sure Danny can rectify it, but it needs the rear arms redesigning IMO, along with taking into account Chip's comments regarding adjustment range. However, this may have partly been due to the excessive ride height required, I'm not sure until the car is properly lazer aligned.
Sounds like the AHMED one is the better item to go for as its been proven. Ł1k well spent if thats what your looking for imo. Any pics of the AHMED beem.
Danny's beem looks smart though and im sure he can sort any issue's.
Slight toe in but without much very much camber.
It was only by putting in more camber I was able to bring it to towing in, without camber its out of adjustment (ie adjuster would fully to toe in) while its still towed out.
I realise the shell's arent EVER straight and this could be specific to this car and others might be ok, so like I said im not having a go, but a bit more adjustment would be a nice to have, especially if you were about to raise and lower it on a rally car for different terrains or similar.
Chip can you pm me the settings you were trying to achieve please,
This issue is going to be taken care of for said car and will be discussed in detail with Harvey when he comes here.
Currently this has only been a problem on this car but I want it solved to make sure there are not continual problems, Also the clearancing require Mike mentions has been improved but its is something that has to be done on Tubular arm set ups Adrenaline or not which is why they are specified as a race only beam,The last beam fitted here had no issues acting as a bump stop as without the shock the driveshaft was the limiting factor on ride height.
Our stg 1 (Ł750)and 2(Ł998) is the bolt on and go which with over 35 sold there has been no problems with fit or adjustment only good comments.
Anyway look forward to your PM and getting this sorted.
X2...........
I will get it all tracked up and stick some pics up of the beam adjusted etc.heres what they look like before fitting
Once that lot is sorted then it's having the frame connectors and the triagular rear strut brace as well
Yeah me too about price, but mine is a road car, its pissed me off that much i dont drive it now.. no ABS aswell..
why are you moaning about the price as well? Ahmed's beam is Ł1k and fully adjustable. You then have to take a big hammer to your car in order to get the Adrenaline one to fit
price didnt bother me, just would of been better if i was told about the mods, i looked into a few different types of axles and decided on dannys, i like it, its a nice piece of kit and lighter
Danny, PM Sent
I hope you can get it sorted, as to me the beam was a fantastically made bit of kit, and the adjusters were great quality etc, both me and Dough Stirling (who was giving me a hand adjusting it) commented on how nice it was compared to a zoo beam etc
Just a shame that the current layout of it prevents the adjustment we were trying to do, but as I said to Micheal at the time, that would be easily fixed.
And to be fair even where we did get it too, it then handled pretty well from the feedback he gave, so where I was attempting to dial it might not even be anywhere it *really* needs to go.
I disagree with Mike on the height needing to come down a lot by the way, as the driveshaft angles (slightly in droop) looked ideal to me.
NOT the stage 1 and stage 2 beams though Rich, only the full race one that Micheal has, which as far as im aware Ahmed doesnt do an equivalent of.
You have to go to Danny's stage 2 beam for both adjustment ranges, which is basically the same price as Ahmed's, so then it is just a choice of who you want to buy off, as both are identically priced
Out of interest how do you adjust the tow on the ahmed beam?
So you could slot the Stg1 beam and it could be the same as the Ahmed one then?
