2.0 zetec... whats this bit do?
Old Jul 9, 2008 | 08:44 AM
vibrating_cake's Avatar
vibrating_cake
Default 2.0 zetec... whats this bit do?
the bit underneath the exhaust manifold with the paper towel covering a hole... whats that???
plasticy iirc??
Old Jul 9, 2008 | 08:52 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Is it the front crankcase breather?
Old Jul 9, 2008 | 09:08 AM
Luca's Avatar
Luca
Lukesville
If it mounts the block by 3 bolts its the crankcae breather... this is my alloy version which is larger in capacity
Old Jul 9, 2008 | 09:15 AM
vibrating_cake
yea thats the one!!
what do i have to pipe upto it if anything?? does it need a filter or anything on it? if so where do i get one from
Old Jul 9, 2008 | 09:17 AM
Luca's Avatar
Luca
Lukesville
Plumb it into an oil breather tank+ same with the one on the cam cover.
Both Piped to a bretaher pot and then put your filter onto that.
Old Jul 9, 2008 | 01:47 PM
vibrating_cake
cool. i have an ally pot hanging around somewhere, will that do?
just use any general hose e.g. heater hose that ive got lying around?
Old Jul 9, 2008 | 02:05 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I wouldn't run anything un-baffled there or you may just end up losing an awful lot of oil up your breather pipe/can when you brake hard!!
Get an original Ford one, either use it or if you intend to 'upgrade', then at least figure out how it works first.
Old Jul 9, 2008 | 02:11 PM
Luca's Avatar
Luca
Lukesville
I have had the Ford one replicated so internally its baffled the oil wont flow up the breather...
The catch tank also i have is the same, but for any oil that does get through it will return to sump via the return pipework.
Old Jul 10, 2008 | 09:07 PM
vibrating_cake
what you mean un-baffled?
i havent got the baffled item i just have the plastic thing on the side. with a gromit in it that looks like it ventilates to fresh air.
i could run a pipe into it so it doesnt come out, and run it up to an oil catch tank, along with the oil breather for the head.
the breather will be located above the height of the cam cover breather and piped with ~ 50cm of tubing.
will this be enough?? and what am i asking for to get the standard item?
Old Jul 10, 2008 | 09:09 PM
JamesH's Avatar
JamesH
The gromit in the top has a valve in it that then links a hose back to the inlet manifold
Old Jul 14, 2008 | 05:55 PM
vibrating_cake
it has that plastic bit on the side.... do i leave it like that, or is that missing something?
Old Jul 14, 2008 | 05:59 PM
JamesH's Avatar
JamesH
What plastic bit on the side?
Old Jul 14, 2008 | 06:29 PM
vibrating_cake
sorry lol
the circled bit
Old Jul 14, 2008 | 06:37 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
There is an outlet at the top right of it, the valve slips into that which connects to a breather pipe which would normally go to the air filter.
Old Jul 14, 2008 | 06:38 PM
JamesH's Avatar
JamesH
Can you not take better pic of the part you mean, cos you've circled the block, head, crank case breather, starter motor, engine mounting arm and a bit of rope!
Old Jul 14, 2008 | 06:39 PM
JamesH's Avatar
JamesH
If he means this, I've already answered
Old Jul 14, 2008 | 06:40 PM
Dangerous Malcolm..
I was just backing you up, he's hard work.
Old Jul 14, 2008 | 06:57 PM
vibrating_cake
and where do i get this valve from? what am i asking for when i go to pay for it!
Old Jul 14, 2008 | 07:02 PM
Dangerous Malcolm..
I think it's a PCV (positive crankcase ventilation) valve.
Old Jul 14, 2008 | 10:03 PM
JamesH's Avatar
JamesH
I just asked for a crankcase breather valve and described where it was, it was about 11quid
Nov 5, 2015 08:12 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Nov 3, 2015 04:08 PM
Ben26
Sep 3, 2015 07:55 PM
Sep 3, 2015 10:49 AM
