rev counter persisting problem
Old Jul 8, 2008 | 08:28 PM
mk3matt's Avatar
mk3matt
Default rev counter persisting problem
hi guys n gals
posted up a few days ago about my rev counter giving out half readngs, some decent fella sent me a piccy, so i got the diodes
they were 1N4004
i wired em in to the car today and it just seemed to short out the car
had to go back to hoe it was
are these diodes 'on way current' jobbies? is there a correct way round to have them? there is a white band on the end of the diode, which end should i connect this to? coming from the coil,,or the other end?
help would really be appreciated guys, i got stuck in soton for 45 mins cos of this lmao, though it would be a 5 min job!
Old Jul 8, 2008 | 08:40 PM
blacky.'s Avatar
blacky.
yes they only go one way
problem is i dont know the way they are ment to be lol
Old Jul 8, 2008 | 08:46 PM
JamesH's Avatar
JamesH
Yes diodes are only meant to be put on one way
Old Jul 8, 2008 | 08:48 PM
JamesH's Avatar
JamesH
I cannot remember if the anode or cathode are meant to be the +ve side, at a guess I'd say the anode
Old Jul 8, 2008 | 08:50 PM
JamesH's Avatar
JamesH
Yes just checked the anode (side without the strip) should see the +ve side
Old Jul 8, 2008 | 08:52 PM
mk3matt's Avatar
mk3matt
cheers guys... but whats the difference!!!!
as i said, on the diode there was a white band at one end, will this attach to the current coming off the coild? or should it be at the revcounter end?
thanks for the help
Old Jul 8, 2008 | 08:53 PM
mk3matt's Avatar
mk3matt
great, thanks, hang on, ill bung a pic up ifor definate comformation!
Old Jul 8, 2008 | 09:01 PM
mk3matt's Avatar
mk3matt
theses are wot i got
wot end goes where lol!
Old Jul 8, 2008 | 09:56 PM
mk3matt's Avatar
mk3matt
any1? would be very appreciative!
Old Jul 8, 2008 | 10:01 PM
blacky.'s Avatar
blacky.
google it
i have done the elecrtics corse 3 times & still cant get my head round most of it
Old Jul 8, 2008 | 11:25 PM
mk3matt's Avatar
mk3matt
lmao, dnt bode well! il work sumit out, anode is the end withouth the white band aoarently...still means bolow all 2 me LOL!
Old Jul 9, 2008 | 11:01 PM
mk3matt's Avatar
mk3matt
right, ive wired it all up correctly, as in the piccie, and im getting no signal to the tacho whatse ever now? ( the diodes are the correct way)
any ideas?
thanks in advance!
Old Jul 10, 2008 | 06:12 AM
Get a decent ecu that can alter the readings/signal or buy a £30 tacho driver.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
