Battery in the boot..
Ok,i think im going to put the bat in the Fiesta in the boot,so i have abit of space for the airfilter....
Has anyone done this conversion,on any car??? IF so,what do i need?? I know i would have to run a live down the car,but would i also have to run a earth too,or mouth that in the engine bay somewhere??? Probabley a REALLY obvious answer,but ust asking???
Pete...
Pete...
Guest
Posts: n/a
The Accuvolt converts battery voltages as low as 9.5 volts to a rock steady user adjustable out put of 13.5 volts to 16.25 volts. This allows the racer to run electronics like fuel pumps, engine management systems, cooling fans and ignition boxes at a consistent high voltage without using an alternato
Guest
Posts: n/a
Guest
Posts: n/a
Real Steel
Unit 9, Tomo Industrial Estate
Packet Boat Lane, Cowley
Uxbridge, Middlesex UB8 2JP
Ph: (01895) 440505
Fax: (01895) 422047
Or
John Woolfe Racing
John Woolfe Racing
Hammond Road
MK41 OQR, Bedford
Ph: 44 1234 220 700
Fax: 44 1234 341 440
Not sure on prices
Ph: (01895) 440505
Fax: (01895) 422047
Or
John Woolfe Racing
John Woolfe Racing
Hammond Road
MK41 OQR, Bedford
Ph: 44 1234 220 700
Not sure on prices
Cheers for that....
Any idea,whats the correct gauge wire???
And when the batts in the boot,just leave the negative terminal on it alone,and earth what did go to it to the body in the engine bay???
Pete....
Pete....
ok, to add more detail, vechiclewiringproducts sell all you need
a junction box to extend the live from the engine bay to the boot
1metre of black 300amp cable, to have some earth the engine to the chassis in the engine bay and some from the battery to the chassis in the boot
around 7-8 metres of red to run to the rear, via a FIA kill switch
get proper clamp ends, again see my sig build for pictures of the parts
get a dry cell battery for safety
