Brake servo swap?
Old Jul 7, 2008 | 10:37 AM
vibrating_cake's Avatar
vibrating_cake
Default Brake servo swap?
Im currently dumping a zetec in the crapi. but i have clearance problems with the brake servo.
i was wondering, would this servo be inter-changeable with the smaller escort servo??? which should give me enough clearance for the zetec and webers.
also what other options do i have??
how do remote servo's work and if i was to run without a servo (for example old mk1's did... what master cylinder should i be using to make it easier to jab the pedal down rather than the std m/c which is designed for use with the servo!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
