escos rims & ap's
Hi there chaps just a quick query
i am currently running ap 4 pots with 330mm discs under 17's, but have always liked escos rims on saphs and set has become available at a very good price so i wa wondering what would i need to change to get them to fit over the ap's is it a case of just new rotors and caliper mounting bracket to suit or not.
Plus what tyres size would you guys recommend profile wise as i was thinking 225's on back and 205's on front but just not sure on profile
It'll cost loads to change and depending on your caliper you may not be able to!
Brackets £150 ish
Rotors £300 ish
Evern then the brakes may not fit as the caliper could still hit the inside of the wheels spokes.
Brackets £150 ish
Rotors £300 ish
james kiely
Aug 28, 2015 08:58 PM
