Advice on ecu chips
Old Jul 5, 2008 | 02:55 PM
roro22's Avatar
roro22
Question Advice on ecu chips
I had mine on the rollers a month ago and the chip I've got at the mo holds 12psi, no idea what make it is (I've not checked yet)
spec is
standard engine
-31 act
Radtec FMIC
Piper Cams operatator on the r/r said they would peak near 6.5k and the current limiter is 5.5k
Edit - And Magnex system and Pipercross Cone Filter
Does anyone recommend any good chips that might suit my setup and take the boost up a bit
A ported head adn hybrid turbo are next on the list after MOT's for 2 motors
Would much prefer to go efi but thats a bit off i think
Old Jul 5, 2008 | 03:00 PM
sm's Avatar
sm
any aftermarket chip will do the job, all they do on a erst is to remove the boost limit allowing you to run more than the std chips 10 psi limit
superchip, turbosystem chipped ecus are on ebay now and again or you could buy a motorsport developments chip from stu on here
Old Jul 5, 2008 | 03:16 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
There are two main types of chip for an rs turbo.. the Superchips and MSD type upgrades remove the boost cut only.. the AB style ones are actually custom-mapped.. It's old hat now and isn't really worth any companys investing time and money into cracking the ecu to custom map it.
Old Jul 5, 2008 | 07:21 PM
roro22's Avatar
roro22
Thanks
So I would really be beter putting it towards efi?
I think I'll get the screwdriver out and see what chip I've got anyway
Old Jul 6, 2008 | 11:27 PM
T28 RST's Avatar
T28 RST
Ok then
Speak to your local tuning companies to see what ECU upgrades they offer
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
tib2220
Sep 14, 2015 12:33 PM
RSmark84
Sep 13, 2015 01:29 PM
