miss fire problem, dodgy injector?
Old Jul 5, 2008 | 12:42 PM
rst in breaking's Avatar
rst in breaking
Default miss fire problem, dodgy injector?
ive got a miss fire problem on my zetec turbo, its running on emerald management and the engine and loom etc is all new, my problem is i have a miss fire on cylinders 2/3, i have a strong spark on all 4 cylinders, i have compression and i've noid tested the injector harness and all are good on all 4 cylinders, i then put 12v to the injectors of cylinders 2/3 both click, so i assumed they were blocked? so last night i removed them and put 12v to them to open them and blew them through as ahmed bajoo said.
Today i put it back together, started it up and problems still there, any suggestions of things to try? can injectors just bugger up? any help MUCH appreciated, thank you
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
stevierob
Sep 7, 2015 07:09 PM
hopper350
Sep 4, 2015 12:53 AM
