manual fan switch
Old Jun 29, 2008 | 12:41 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default manual fan switch
how do i fit a manual fan switch to a series 2?
Old Jun 29, 2008 | 12:45 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
connect it up to the + wire on the plug to the fan sensor in the thermostat housing.
Worked just fine for me
Old Jun 29, 2008 | 05:58 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
why do ya need 1?
Old Jun 29, 2008 | 06:21 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
so i decide when my fan cuts in, i have to change my fan switch as the fans dont kick in no more
Old Jun 29, 2008 | 06:42 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
same should apply to an S2
Old Jun 29, 2008 | 06:48 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
do i have to take the fan plug out and extend that wiring?or does the plug stay in the switch?
Old Jun 29, 2008 | 07:48 PM
vroooom ptssssh
It Wasnt Me!
plug stays on the switch, you tap into the wires to the plug though!
Old Jun 29, 2008 | 11:24 PM
Smartdj.'s Avatar
Smartdj.
why dont u just buy a new temp sencor.....the one in the rad
Old Jun 30, 2008 | 05:44 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
is the temperature sensor easy to fit?
Old Jun 30, 2008 | 07:13 PM
Smartdj.'s Avatar
Smartdj.
havent checked but i think it screws in m8
Old Jun 30, 2008 | 07:43 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
where abouts is it in the radiator? cuz i cant see one
Old Jun 30, 2008 | 08:24 PM
project rs's Avatar
project rs
the temp sender is in the head just to left of the thermostat housing and the switch that controls the fan opertation is just under the thermostat housing and to see if the switch is at fault pull it off and place a piece of wire in the bit you've pulled of and the fan should come on, if not check fuse isn't blown and lastly if you know how and have got a multi meter check you've got a live to fan if so could be fan motor that has gone
Old Jun 30, 2008 | 08:49 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i thought the temp was in the head! its defo the fan switch as my fans work when put wire on positive and put it on the battery. i changed the switch now so they should work
Old Jun 30, 2008 | 10:07 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
you can connect them to a switch inside your car if you want (i dont trust this as i would prob forget to turn them on) its really easy all you need is a 2 way switch and just extend the wires that go to the fan switch make sure you unplug them from your fan switch and just connect them to your switch and attach an inline fuse just to be safe then just turn them on when you want.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
