Escort Rs Turbo S2 Playing Up Big Time !!!!!
Old Jun 28, 2008 | 06:09 AM
turbolee1977's Avatar
turbolee1977
Default Escort Rs Turbo S2 Playing Up Big Time !!!!!
hi can anyone help. ive got a s2 which was burning the fuel pumps out and the relays i sorted that problem out but ever since ive sorted that problem out my car wont rev it runs for about 30 secs then cuts out its popping and banging. changed metering unit,spark plugs, throttle sensor etc etc. . . checked all pipes they are fine
Old Jun 28, 2008 | 06:25 AM
CharlieMac's Avatar
CharlieMac
Has there been any wiring work done on the car recently? Seems strange that there you have mentioned three electrical problems all possibly linked? May be a problem with the wiring? What about the distributor and module etc? I presume it's standard ignition system? Hope u find this helpful.
Charlie
Old Jun 28, 2008 | 06:27 AM
turbolee1977
Charlie
hi thanks for replying we did mess about with the wiring trying to see wat was burning the fuel pumps out and i had the dash out put that back in and found a wire under the bonnet that was earthing the car
Old Jun 28, 2008 | 06:47 AM
CharlieMac's Avatar
CharlieMac
My advice would be look at the wiring diagrams, unplug the distributor, metering head, etc working your way thru all the ignition and fuel side removing one plug at a time and check the power supplys and earths for each component. More than likely that something has been disturbed while you had the dash out? That's just what I would do, before you go to all that hassle, how good is your distributor? as they have a habit of going on RST's, I had to replace mine twice, ended up just buying a brand new one from Lucas or whatever it is they call themselves these days? If you have access to a known dizzy that works swap them and see if that sorts it?
Billy_RS
16
Oct 11, 2025 09:41 PM
A.t.p
Aug 15, 2015 11:37 AM
Blown Hell
Aug 5, 2015 07:22 AM
marky_g
Aug 3, 2015 04:45 PM
adriansaleem
Aug 1, 2015 09:28 PM
