4wd caliper question....
Does anyone know the distance between the mounting bolts (7mm allen key) on the caliper to carrier on a 4wd Cossie front caliper???
ta for any help
Steve
ta for any help
Steve
the same as every other ford, around about the 91mm from centre to centre if you are on about the distance between the bolt holes
if it's anything else, i'm not sure what you are on about
