Swedish Plenum Hose
Old Jun 27, 2008 | 03:47 PM
montecos400's Avatar
montecos400
Default Swedish Plenum Hose
I havent fitted my swedish plenum yet and just want to know if my exisiting boost hose will fit or will I need a new one. This will be connecting a standard rs500 type i/c and standard throttle body.
Old Jun 27, 2008 | 05:12 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Depending on who made it and the design of it, normally you may just need to cut the original hose a little shorter - they normally fit straight on, just shorter as the TB is right on the front of the plenum, which is then that little bit closer to the IC.
HTH,
Si
Old Jun 27, 2008 | 05:34 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
and roose make a swedish plenum hose
Old Jun 27, 2008 | 06:03 PM
col cos1's Avatar
col cos1
get a s2 hose from roose cheaper than there sweedish one,mine fitted perfect
Old Jun 27, 2008 | 06:46 PM
montecos400
Cheers for the replies. Am I right in thinking the standard i/c ports are 76mm?? and throttle body 63mm (2wd cosworth)
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
