Bolt In Roll Cage Fitting Advice Needed!
Whats good/normal practice;
Bolt heads inside the car with nut and thread underneath, or vice versa?
bolt in cages are fine for motorsport.
make sure it's bolted to proper strengthening plates and the bolt heads are inside. nuts on the outside.
make sure you use the correct type of bolt as well!
Cheers mate,
No worries about the plates, its an FIA cage, so have used the ones that came with it, and triangulated the A and B pillar ones to the sill too...
And i'll use the nuts and bolts that came with it!
track.focus'd
Aug 12, 2015 05:53 PM
xr4x4rs
Aug 6, 2015 09:03 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
