Whats involved, s2mfi to fez efi conv
Old Jun 25, 2008 | 07:14 AM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
Default Whats involved, s2mfi to fez efi conv
I have a s2 rs turbo running mfi, im buying a fiesta rsturbo engine and loom. Has anyone done this before? if so can anyone tell me what is involved, is it a straight swap or are both looms incorporated into each other to make existing things work such as rev counter etc. Advice on this subject would be most appreciated as im totally in the dark
Old Jun 25, 2008 | 08:42 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It's been done hundreds of times, best to search the forum.
Old Jun 25, 2008 | 09:08 AM
NATH-RSZT's Avatar
NATH-RSZT
you could just get a 90spec efi xr3i loom as they fit straight in a s2. then the ofac frst setup plugs staright in and if you want to run ofab you only need to change a few wires on the loom. easy.
I know the wire changes needed if you run ofab.
Prickly_buzz
Dec 7, 2017 09:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
