Amp Blank Tray Ref no Required please
Old Jun 24, 2008 | 08:56 PM
Gez500's Avatar
Gez500
Default Amp Blank Tray Ref no Required please
Has anyone removed their amp and fitted one of the felt like material blanking trays from Ford? My dealer can only come up with an all plastic tray. If anyone has one, and can let me know the long reference number on it, it'd be much appreciated.
Cheers, Gez
Old Jun 24, 2008 | 10:20 PM
iansoutham's Avatar
iansoutham
OCD Victim
As standard, the Sierra only had a plastic box, but I believe the Mondeo MK1 and MK2 may have had a felt-lined one.
The basic number for that is 93BG 13530 BA, or finis 6716715.
This assumes you have a post Jan 1990 car. If yours is earlier (long, thin tray with screws holding it in) then I would not know.
Old Jun 25, 2008 | 06:01 AM
I've never seen a felt tray, my std cossie one is all plastic, where the amp would be in other cossie's.
I can easy get the number of the std plastic one if you want ?
Old Jun 25, 2008 | 06:31 AM
Vic's Avatar
Vic
is there one for the 3 door that replaces the amp?
Old Jun 25, 2008 | 10:09 AM
Moonstone Mo's Avatar
Moonstone Mo
so is this the part number for a 4x4 sapph as the 2wd are slightly shorter?
Old Jun 25, 2008 | 10:16 AM
3 door one same as xr4i, which can have a little pocket piece in place of amp.
Old Jun 25, 2008 | 10:17 AM
I assume from the 93 it is reffering to the mondeo part number, though some had a cassette tray there instead, holding 8 cassettes.
Old Jun 25, 2008 | 10:45 AM
iansoutham's Avatar
iansoutham
OCD Victim
You would be correct Tabetha.
The number is for a Mondeo one, and they had the option of:
a/ tape holder
b/ tray insert
c/ CD player
wowk
Mar 30, 2021 07:49 PM
Fudgey
21
Sep 30, 2015 06:19 PM
20/20 vision
Sep 29, 2015 09:25 PM
