mahle forged pistons..
Old Jun 23, 2008 | 09:56 PM
bonus_boy's Avatar
bonus_boy
Cool mahle forged pistons..
just wondering if theres low comp or normal comp pistons, or are they all the same?
or does the headgasket lower the compression?
also how much would a good condition set of these pistons set you back (with conrods) 2nd hand?
cheers
Old Jun 24, 2008 | 10:56 AM
bonus_boy's Avatar
bonus_boy
Old Jun 24, 2008 | 11:00 AM
rsdan123's Avatar
rsdan123
you can buy standard comp pistons or lower cr ones. check out burtons power... pricey but some good stuff
Old Jun 24, 2008 | 11:05 AM
bonus_boy's Avatar
bonus_boy
i know of some 2nd hand pistons and rods going in good condition...
there 8:3:1 comp ( someone just said they aint even cvh pistons :S )
just stuck!
Old Jun 24, 2008 | 12:54 PM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
Smile
just stuck!
its more important that they are forged if you are using for a turbo, low comp can mean a variety of of thigs, usually meaning that the piston crown has been decked/shaped to lower the compression. Trouble can arise from using thinker gaskets as a means of lowering compression whe high boost levels are used. For what they cost, go for new, as preveously mention burton sell acrylite pistons which are forged, they will also machine the pistons down to whatever compression you require. Cost id £170 per piston, standard rods should be fine for up to 18psi or 220 - 250bhp. If you want to push the boat out get steel rods at £170 ish each but this all depends on the spec you are after. Buying 2nd hand usually ends in tears, as I have found out with my little rs :-(
Hope this helps mate
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
cossie09
Oct 11, 2015 06:29 PM
richierich1986
Sep 18, 2015 03:29 PM
mattxr3i
Sep 13, 2015 05:52 PM
