air leak?
Old Jun 23, 2008 | 08:45 PM
adam r.s.t's Avatar
adam r.s.t
Default air leak?
my r.s.t runs fine when driving,or when its cold,but when sitting in traffic for a few minutes the idle drops right down and will stall if sat for long enough,ive replaced all the plastic pipes on the breathin system,but no luck,is it metering head?or can i try anything else?
Old Jun 23, 2008 | 08:48 PM
haz87's Avatar
haz87
Inlet manifold gaskets, brake servo, vacuum pipes, the list is endless. Is your fuelling ok?
Old Jun 23, 2008 | 08:49 PM
g1234's Avatar
g1234
try spraying easy start around things if it picks up in a spesific area there must be a air leek near by
Old Jun 23, 2008 | 09:14 PM
adam r.s.t's Avatar
adam r.s.t
the feuling is ok,it was set up not long ago,ive got sum easystart il try that this week,otherwise il have to start replacing gaskets!
Brickhouse
14
Oct 3, 2015 07:28 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
