easiest way for efi
Old Jun 22, 2008 | 04:18 PM
rs-tuner's Avatar
rs-tuner
Smile easiest way for efi
i am rebuilding my standard s2 and have decided to stick with the cvh whats the best way to convert to efi should i buy an efi head and use it on my standard block cheers folks.
Old Jun 22, 2008 | 04:52 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
if u got a hole for the cps then u can use ur bottom end,if not u need a efi bottom end,or have yours drilled or set up a trigger wheel,TBH i think EFI is over rated
Old Jun 22, 2008 | 06:16 PM
Chris69's Avatar
Chris69
you really need a complete efi turbo engine mate or just the head plus your mfi block will need doing- along with the associated wiring of course- do a search on here its covered an awful lot
so your zetec in your sig is on mfi is it
Old Jun 22, 2008 | 06:31 PM
orion_crazy_carl
orion=mini saff
lol,good point mate, i mean on a conversion for a S2,MFI is good for good power!money is better spent else where IMO!
Old Jun 22, 2008 | 07:08 PM
Rab's Avatar
Rab
Fucking superstar........
Don't be daft! Every time an S2 is sat at the side of the road waiting on a recovery truck it's because of MFi..... Stupid crappy pissy system thats useless.....
FIRST thing I'd be doing with an RST is binning the MFi and getting something better. Some great systems out there for not alot of dosh.
Old Jun 22, 2008 | 08:14 PM
Chris69's Avatar
Chris69
couldn't disagree more tbh, i had mfi on my s2- had nowt but problems with air leaks, dodgy metering unit, fuel blockages, bad cold start etc
had it converted to efi and it starts and stops on the button with no problems so far, power ain't everything
Old Jun 22, 2008 | 08:53 PM
rs-tuner's Avatar
rs-tuner
Smile
cheers guys on the hunt for a frst engine now
Old Jun 22, 2008 | 10:28 PM
orion_crazy_carl
orion=mini saff
had mfi for years nosw no problem,it works fine if looked after!!!fezzie EFI is a pain,other systems are good tho
Old Jun 22, 2008 | 10:50 PM
denbo's Avatar
denbo
CHUNT69-couldn't disagree more tbh, i had mfi on my s2- had nowt but problems with air leaks, dodgy metering unit, fuel blockages, bad cold start etc
Am with you on that fella am just getting all the bits in now ready for my EFI conversion and with Cossie management
Old Jun 23, 2008 | 06:45 AM
robj20's Avatar
robj20
Just had mine converted to efi after having lots of trouble with starting and idling. Works great now, and uses a lot less fuel.
Old Jun 23, 2008 | 02:47 PM
mentalasanything's Avatar
mentalasanything
Currently gathering the parts to convert my S2 to EFi. I've gone for a diferent approach though. I've opted to keep my block (Rebuilt not long ago) with a EFi CVH head and the 1.8cvh aux belt pulley with trigger wheel and cps there rather than with the Flywheel.
All I need is to chose the management.....
There's a few options but as said do a search, this has been asked a few times!
Lee
Old Jun 24, 2008 | 01:08 PM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
well no one has mentioned the gotech option, im in the same situation, i have a stage 3 spec engine which is on mfi, but is limited to fueling due to the metering unit. Jamsport provide everything you need to convert to efi yourself for Ł1400, you dont have to do anything to your existing engine. In fact you can remove the metering unit which you can sell to regain some money. its a simple plug and play install, it gets the tdc information by pluging into your dizzy. Ive been talking to jamsport and have bought a lot of the required parts saving even more money, the gotech management is very advanced too (apparantly) superior to even cossie management.
Hope this helps
Old Jun 24, 2008 | 01:21 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
At the end of the day engine management is only as effective as the mapper no matter how advanced it is and as such you should find your mapper and then follow their advice and use the option they have the most experience and knowledge of.
Every system has good and bad points, even MFI its a fact !
Old Jun 24, 2008 | 01:57 PM
Turbocabbie
Top Cab !!
Worth remembering that the fastest Escorts in the UK run Cossie management
A dizzy based system does not seem advanced, I even run coil pack on my cossie management
What makes it more advanced ?
and what model gotech are we discussing here ?
Old Jun 24, 2008 | 02:02 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
From what i've seen, GoTech looks awful to map... There are lots of different aftermarket ecu's, many barely mentioned on PF..
Old Jun 24, 2008 | 02:23 PM
NEWTON's Avatar
NEWTON
what about c&bs thats on omex
Old Jun 24, 2008 | 02:52 PM
robj20's Avatar
robj20
mine is on gotech, you can run it with your current coil or go coil pack, seems very easy to map if you ask me as soon as i got it home i had my laptop plugged in and the software loaded up.
Old Jun 24, 2008 | 08:25 PM
Raj B's Avatar
Raj B
im only going on what the lads at jamsport told me, i know they will be biased in that they are the only gotech dealer but if your engine is mfi and spec'd up like mine, its more cost effective. They explained that gotech (the gotech pro) has many extra options built in and has more parameter settings as opposed to cossie magagement, launch control, boost control, anti log - atuff i wouldnt use tbh. imo i think that cossie/omex is more of a expensive trend bown up by the mags, a gotech ecu and loom costs 375. Not bad for what you get! im still baffled at all the different options, was just wondering, have found an engine up for grabs, its a fez 1600, is it hard to incorporate the 1600 loom with the existing mfi loon I already have?
Old Jun 25, 2008 | 06:03 PM
NEWTON's Avatar
NEWTON
no it not hard to wire in the frst stuff
Old Jun 25, 2008 | 07:15 PM
Raj B's Avatar
Raj B
nice one newton, hopfully gonna get the engin and stuff on friday, so my stage 3 spec engine will be on flee bay to help recouperate some needed pennies.lol
mk1turboestate
Dec 2, 2015 08:31 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
