hpi savage x problem
Old Jun 21, 2008 | 09:48 PM
mattyb1981's Avatar
mattyb1981
Default hpi savage x problem
my savage x 4.6 keeps eating spur gears and i dont know why? i have changed the engine plate becuse it was bent but still strips the gear, anybody got any ideas why?
Old Jun 21, 2008 | 09:50 PM
pani_k's Avatar
pani_k
PassionFORD Member
sounds like your engine is vibrating itself loose and coming away from the spur gears and chewing them to pieces. Clean the screws you use to mount the engine from the underside of the chassis and the threads and use some threadlock. Either that or your layshaft is bent and the spurs aren't sitting right.
Old Jun 21, 2008 | 09:51 PM
Munch's Avatar
Munch
Mr. Sparkle!
plastic is shit & your probley doing the Clutch up too tight, loosen it
Steel conversion is the way forward
Old Jun 21, 2008 | 09:52 PM
Munch's Avatar
Munch
Mr. Sparkle!
fuck all to do with it
its the Slipper Clutch...its done up too tight, i know it, i own one
Old Jun 21, 2008 | 09:56 PM
mattyb1981's Avatar
mattyb1981
there seems to be a bitof a wobble on the spur when you sin it could this be causing the problem?
mattyb1981's Avatar
mattyb1981
ive heard differnt stories about the steel suprs tho some say do it other say dont?
Old Jun 21, 2008 | 09:59 PM
Munch's Avatar
Munch
Mr. Sparkle!
wobble? mine didnt spin straight when i put the steel conversion on, turns out 2 of the screws on the gear fall out that hold the gear onto the plate, pretty much took a chunk out of the clutch bell, this wouldnt happen on a plastic one anyway
trust me, your clutch is far too tight!
Old Jun 21, 2008 | 10:00 PM
Munch's Avatar
Munch
Mr. Sparkle!
had my X for about 2 years now, would of given up onit if i didnt have the Conversion
dam your making me miss the fight! lol
Old Jun 21, 2008 | 10:02 PM
mattyb1981's Avatar
mattyb1981
im new to all this so bear with me, im going to sound really stupid now do you mean the slipper clutch on the back of the spur or somthing else?
Old Jun 21, 2008 | 10:06 PM
pani_k's Avatar
pani_k
PassionFORD Member
The "usual" stripping gears cause is the pinion and spurs coming apart under vibration. I thought that would be a good starting point.
As for the Savage slipper clutch setup, I haven't any experience of that but my nitro and electric car knowledge would prompt me to look that I have the engine and spurs aligned properly and that they aren't vibrating loose. Simply what I would do.
Old Jun 21, 2008 | 10:08 PM
mattyb1981's Avatar
mattyb1981
i have meshed them up using the paper trick and thread locked the bolts tight so i would hope it hasnt moved?
Old Jun 21, 2008 | 10:11 PM
Munch's Avatar
Munch
Mr. Sparkle!
on the Spur gear, there is a Nut holding it on, with a little like spring onit yeah? Tighten it then loosen it like a turn & abit, it will be in the manual
There will be an Matching picture of what the Clutch bell & Spur gear, how much gap there should be between, basicly you want 50/50, you want it to Roll freely, if you cant roll the car, then your engine needs moving abit to the side
but plastic Spurs strip all the time if they are tight.
Old Jun 21, 2008 | 10:14 PM
mattyb1981's Avatar
mattyb1981
ok ill try it with the spur a bit looser, i had read somewhere that its best to have it as tight as possible though?
Old Jun 21, 2008 | 10:15 PM
Munch's Avatar
Munch
Mr. Sparkle!
no no no, thats why it is stripping your gears LOL
you will read this in the manual lol
Old Jun 21, 2008 | 10:17 PM
mattyb1981's Avatar
mattyb1981
ok i will try it this way and lt you now thanks for the advise
Old Jun 21, 2008 | 10:20 PM
Munch's Avatar
Munch
Mr. Sparkle!
no problem
There fun, but i dont use mine so its going Monday to an New owner & my Hunter
Will miss the SavFender, she is a beast!
Old Jun 21, 2008 | 10:26 PM
kiddie's Avatar
kiddie
good post, mine is in the garage needing a new one. But I just ordered two new standard ones, might look at the steel route next time. Is it that straight forward or does the whole clutch bell need changing?
Old Jun 21, 2008 | 10:35 PM
Munch's Avatar
Munch
Mr. Sparkle!
http://www.hpieurope.com/walk.php?lang=en&id=14
cost me about 60 squid iirc
Old Jun 21, 2008 | 10:44 PM
Rippers's Avatar
Rippers
Monte Geek
IIRC stripping gears are usually done when you accelerate in the air mid jump, but thats the only way you can straighten them so they land properly so I guess a steel conversion is they only way to stop this if you like doing jumps?
Old Jun 21, 2008 | 10:46 PM
Munch's Avatar
Munch
Mr. Sparkle!
sounds like yours is too tight too paul, loosen it pal
Old Jun 22, 2008 | 08:53 AM
mattyb1981's Avatar
mattyb1981
if it was because i was doing jumps i could understand but mine don't last long enough to do any jumps lol
Old Jun 22, 2008 | 11:04 AM
Munch's Avatar
Munch
Mr. Sparkle!
have you loosen it abit yet?
Old Jun 22, 2008 | 01:12 PM
mattyb1981's Avatar
mattyb1981
have not been able to get a new spur yet today,a friend of mine has some spares at his house but hes out at the moment so just waiting for him to come home and will try it
Old Jun 22, 2008 | 01:20 PM
Munch's Avatar
Munch
Mr. Sparkle!
fair enough pal
when you loosen it, you may notice an performance increase too
Old Jun 22, 2008 | 01:30 PM
vinnyvangough's Avatar
vinnyvangough
My X is in about 3 main piece's atm, Need new diffs all round, driveshafts, plastic supports and really a new chassis. Ooops
Old Jun 22, 2008 | 09:57 PM
mk1 martin's Avatar
mk1 martin
tis gooood..
gutted i sold mine ..had a alloy spurgear worked a treat
Old Jun 23, 2008 | 07:46 PM
mattyb1981's Avatar
mattyb1981
hello people i replaced the damaged spur with a new spur tonight and meshed it up with the help of a friend and it works a treat, it seems that the spur was to tight only problem now is that one of the brake pads has popped out at least its going forward now
Old Jun 23, 2008 | 08:21 PM
Munch's Avatar
Munch
Mr. Sparkle!
you mean one of the Slipper pads on the clutch, you can buy them anyway
told you, it was too tight
Sold my cars this afternoon
Old Jun 24, 2008 | 06:52 AM
mattyb1981's Avatar
mattyb1981
no not the slipper pad on the back of the slipper, i have the twin s/s disk setup and one of the pads has come loose so i had to take the car apart rebuild the brakes then put car back together again, just hope it still works
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fil
Sep 30, 2015 12:08 PM
stevecfrst1
Sep 30, 2015 05:18 AM
