cosworth pressurising
Old Jun 20, 2008 | 04:37 PM
jackos1's Avatar
jackos1
Default cosworth pressurising
hi there guys i have a 2wd sapphire cosworth recent rebuild. recently my brand new alloy radiator started leaking so i got it fixed by my local radiator company and now seems fine but my coolant system wont stop pressurising and trying to blow my cap off water bottle thermostat ok so is radiator fan switch. any help would be good thanks
Old Jun 20, 2008 | 04:43 PM
charlie luciano's Avatar
charlie luciano
Must have some sort of blockage in the cooling system somewhere, give it a flushing,
Luciano
Old Jun 20, 2008 | 04:55 PM
AndyPen's Avatar
AndyPen
Is this when its hot mate? If so get the gasses checked in case the head gasket has had it. If its cold it must be a blockage I guess??
Old Jun 20, 2008 | 05:53 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
pump impellor?
Old Jun 20, 2008 | 06:15 PM
jimmy/taylor's Avatar
jimmy/taylor
Have a feel of the hoses(watch your fingers) and see if any are cold.
If one rad hose is cold and the other is warm,it could be a blocked radiator,same applies to the water pump/heater matrix/header tank. try having a smell of the header tank coolant. usually a hint of hydrocarbon(exhaust gas) if your head gasket is fooked. a gas analyser would show it better. sometimes they're just airlocked and need ticking over with the rad cap off for a bit. check the heaters blowing hot as well. good luck.
Old Jun 21, 2008 | 07:55 AM
legend289's Avatar
legend289
I`d put money on it being either a head gasket problem or a crack somewhere. Sorry to be bringing doom and gloom...
Old Jun 21, 2008 | 08:38 AM
righthooker's Avatar
righthooker
i`m with you,seen it once head was scrap
Old Jun 21, 2008 | 09:08 AM
SWIFTY's Avatar
SWIFTY
Mine Did The Same Thing Changed Everything Inc Headgaskit, Rad, Stat And Fan Switch Cost Me Loads Had People Who New What They Were Doing Look At It With No Look Ened Up Being A £8 Header Tank Cap.
The Cap Was Letting Air In So Would Pressureise Alot Earlyer Than Should.
Speeling Is Not My Strong Point
Old Jun 21, 2008 | 10:53 PM
legend289's Avatar
legend289
If you can get it to a local garage, just get them to stick their exhaust gas analyser into the header tank to see if it sniffs exhaust gases, if it does, you have your answer.
Old Jun 21, 2008 | 10:56 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
rad cap, cheapest thing to try after feeling hoses for temps.
Dan
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
