4wd intercooler????
Old Jun 19, 2008 | 05:00 PM
RS SHAUN's Avatar
RS SHAUN
Default 4wd intercooler????
what alterations do you have to do to fit a 4wd intercooler to a 2wd saph? do you have to drop the radiator down abit, and the intercooler mounts are wider????? doin my head in!!!
Old Jun 19, 2008 | 05:21 PM
charlie luciano's Avatar
charlie luciano
Scrap the 4x4 cooler idea, ebay it then get yourself a 500 cooler a lot less beef
Luciano
Old Jun 19, 2008 | 06:44 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Have mine for sale. If you're interested, just drop me a PM
Old Jun 19, 2008 | 07:08 PM
To fit 4wd i/cooler to 2wd, remove(by cutting) the support that goes between the cooler and rad nearest the offside wing, space out to 22" between the centres of each support and reweld on to rad.
This is now spaced correctly to fit, the bobbins on the i/cooler will need pushing down a bit to go on the rad but will fit with a bit of a push to get nut started, they have 82% more area by the way.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
