what sends the signal to the metering unit?
Old Jun 19, 2008 | 03:26 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default what sends the signal to the metering unit?
what sends the signal to the metering unit? i cant get any juice up 2 my injectors, does the meterin unit it force juice up there, or is it sucked up like a vacum, iv changed pump/ecu/meterin unit x3, got spark, any ideas
Old Jun 19, 2008 | 04:40 PM
juffer's Avatar
juffer
if you haven't triyed, bridge the fuel punp relay so its on constantly then hold the flap down for a few seconds, you maybe better off pulling an injector out so you see the fuel coming out so you dont flood the engine.
Old Jun 19, 2008 | 04:43 PM
juffer's Avatar
juffer
oh and to your question "what sends the signal to the metering unit?" you can disconect the sensors and it will still run not 100% but it will its the flap bobbing up and down which allows the fuel delivery.
Old Jun 19, 2008 | 04:44 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Metering heads are aggro
Old Jun 19, 2008 | 06:53 PM
gee1599's Avatar
gee1599
i had this problem and it turned out to be the filter in the tank but i had running problems as well
Old Jun 19, 2008 | 07:18 PM
paul66 turbo's Avatar
paul66 turbo
Default rs
hi mate had the same problem mine was the black fuel ecu have you changed this or just the silver 1
Old Jun 19, 2008 | 07:46 PM
TuRbO-CaB-LaD
cheers, iv changed the black ecu, i will try bridging the relay 2morrow, there is a relay in my fuse box got ke on it, do u think this is worth changing/bridging?
gingeRS
17
Oct 2, 2015 09:42 AM
Steve Escos
Oct 1, 2015 06:57 AM
Fordmad!
Sep 29, 2015 07:03 PM
