Rebuilt Fiesta rst engine
This was going in a mates track day car but hes just got a 2.1 so no longer needed.
It was fully rebuilt by Power engineering 5k ago & was only running 12psi when i took it out it had a full strip down & everything was checked,All the bearings are still as new as are the rings & bores (.5 oversize). It has ARP rod bolts otherwise standard bottom end. The head has been rebuilt with new valve stem oil seals,valves have been lapped in it also has a kent cvh 35 cam kit with piper pulley.
IT has had new felpro head gasket,head bolts,cam belt,waterpump,oil filter,spark plugs,sump gasket,exhaust manifold studs & nuts.....This list goes on i have most of the reciepts for the bits from burtons.
This is a mint engine inside & out that wants for nothing.
£600 thanks.
£600 thanks.
Billy_RS
16
Oct 11, 2025 09:41 PM
