Changed my clutch - won't grip :S
Hi nightriders.
I've just(almost five hours ago) changed my clutch to a 6puck sinter, with modified pressureplate(more pressure type of modifing)
But, the old have had a tough turn and there's some marks on the flywheel. I guess it got a little too hot or something, but feels smooth enough and haven't got any marks or anything.
Well, we bolted the lot together and pulling off the lift it immediatly feels sooooo good comparing to the 4puck I relieved hours earlier.
Driving out on the main road problems comes to the surface, in the shape of (don't know how you say it in english) "sluring". Meaning the clutch won't grip.
So, can the flywheel be so damaged, even if it feels good, that I will have to replace it ? Or is there something else causing this ?
Thx for reading through, will surly appreciate every single helpful answer
(Sry about the english)
Hi mate, I think alot of people would of got the flywheel skimmed (sliped) but if you say it not too bad then i think it will maybe take a bit of time for the clutch plate to bed in, The same as brakes are always shit for a while til they bed in.
Also double check the auto adjuster on the peddle is not too tight causing it to be putting pressure on plate. good luck
Regards steve
Regards steve
Adjusted the thingy on the pedal today, seemed like it was all good on the testdrive, wheelspin in third gear, but when the rain dryed up it was back to crap. Seems like we have to change the flywheel
