you need deep pockets.....:(
some of you may no the trouble i have had my car kept over heating so i changed the rad,stat,fan switch,header cap then the headgaskit, all went well for about 1mile when my new cambelt snaped and bent all 16 valves then when i took the cams out they were scrap, so i brought a second hand head from a rs breakers in derby put that on started it sounded fine drove about half a mile an then started popin and banging out of the air filter and the idle sounded like a subs, done a compression test an they all seam fine checked the leads plugs and dizzy they all seam fine timings also fine. also if you hold the throttle open to a fast idle its sounds alot better its when you blip it, it pops and bangs.
so if anyone has any ideas pleas help.
ps its missing on number 4 as if you take the lead out while idling it makes no diff but the rest it does
thanks
thanks
After Checking The Dizzy Leads Plugs And Injectors Decided To Take The Cam Cover Off And Have A Look And I Think I May Of Found The Problem The Cam Was Snapped In Half
Can Some One Tell Me Please What Way The Cam Caps Go On Is It Num 1 On The Front Right Or Front Left As On One Of My Heads Is One Way An One Is The Other And Want To No What One Is Right So It Goes Back Together Right
Thanks
Thanks
