A few questions about parts I need..?
Can anyone tell me what the pressed steel panel that goes from inner wing to inner wing and seperates the engine bay and the heater motor/wiper motor area is called? are they still available?
Also are battery trays still available or will I need to fabricate one?
Im looking for one of these. i have a good 2nd hand but would like a new one. As tabetha said Hadrian are good also beevers is another good spot. not seen one mind...Tray should be no prob..
MK1 sierras there are lots of different ones, MK2 they are all the same but the centre section, the plastic bit is different from model to model on some.
A MK1 panel fitted to a MK2 will be ok until up at the battery end where the MK22 panle sits a LOT further forward, so bonnet will not close on the seal, it will still shut no probs but not seal as seal will be in wrong place.
I made this mistake last year!!
andrewmctiernan
Sep 8, 2015 03:05 PM
