Clutch Fitment
Anyone have any tips on fitting a new clutch.Engine have to be tilted back?cam cover off? engine mounts undone? any tips gratefully received.Regards Robbie
I changed the clutch on a 4x4 sierra once and that is the same running gear , and basicly you remove the exhaust ,disconnect the front diff axel and the prop shaft get the gearbox out (dont forget the clutchcable) refit the new clutch and put it back together !
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
