ZVH swap?
Old Jun 13, 2008 | 08:22 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Default ZVH swap?
Amyone fancy swapping a nice 1600 cvh RST bottom end for a freshly built (or it will be freshly built when I put it together!!) 1800 XR3i Zetec bottom end? New shells, mains, std pistons (unskimmed at the mo but may well be by the time I build it)
NO wear on the bores whatsoever, sump already has oil return ally welded in and relevant breathers blocked. ready to ZVH. Already has the block drilled and tapped to accept a CVH water pump. All you'll need to do is make/buy on eBay a water pump plate and a 1300 cvh cambelt tensioner and bung a CVH head onto it
PM if you're interested please
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
grishenko45
Sep 9, 2015 12:58 PM
