cooling systems Q
Old Jun 11, 2008 | 06:46 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default cooling systems Q
i have a retro ford zeted stat pipe thing that relocates the stat to the side of the block for rwd fitment.
now, the rear of this is the return for the heater matrix, and has an M8 tapped hole to connect to the matrix - is this going to be too small a hole and cause any problems at all?
i dont have a fitting yet, but im gueesing the ID of this will be around 6mm?
its the black thing tot he left of the down pipe, the bit im on about you cant see as its behind the block
thanking yaw
Old Jun 11, 2008 | 06:53 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
6mm for the matrix will be ok, will still get hot.
Old Jun 11, 2008 | 06:57 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yeah, its on the return side so i thought as much.
cheers bud
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
coscor86
Sep 20, 2015 01:21 PM
