Focus ST engine fault (volvo)
Old Jun 11, 2008 | 11:28 AM
JonnyBravo's Avatar
JonnyBravo
Default Focus ST engine fault (volvo)
I was having a quick convo with a friend of mine last night and he mentioned he has had some issues with his ST engine, basically its breathing excpetionally hard from what I could make out.
He mentioned there has been faults on these engine with a diaphragm spiltting behind the oil filter housing or something Can anyone clarify this ?
Have the ST's had any dramatic problems ? I'm guessing there is one or Ford mechanics on here who could answer that
Its not covered by warranty as its mildly modded so it needs to be sorted and he understandably doesn't want to take it anywhere thathaven't got a clue about the car.
Any help would be appreciated
Old Jun 11, 2008 | 11:29 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
There aren't many problems with these.. gearbox mounts breaking.. some have had failed liners (inducing HG failure).. but that's about it!
Old Jun 11, 2008 | 12:24 PM
JonnyBravo's Avatar
JonnyBravo
bump
Old Jun 11, 2008 | 12:32 PM
Dave Henshall's Avatar
Dave Henshall
THIS IS THE KIDDY...
FITS HERE...
UNFORTUNATELY....
This diaphragm is not available separately. only the housing only finis 1370976 @ £117.18 inc vat
Old Jun 11, 2008 | 01:10 PM
JonnyBravo's Avatar
JonnyBravo
Cheers Dave, do you know of a fault with that part then ?
Old Jun 11, 2008 | 05:11 PM
B19 JUB's Avatar
B19 JUB
i work for a ford dealer and have changed a couple of these.crankcase oil seperator something like that.causes engine light on saying too much air due to it drawing it in through said diaphram
Old Jun 12, 2008 | 12:56 PM
Dave Henshall
has happened to a few cars, std and modified cars and is caued by excessive boost levels apparently.
Old Jun 14, 2008 | 03:10 PM
James's Avatar
James
on back order from germany aswell, unsure when the will be here!
problem is a whisling noise, take the oil cap off with engine running and the noise stops.
Old Jun 12, 2011 | 09:25 PM
markfishing's Avatar
markfishing
Default high pitch noise
hi dave , ive got this fault ,, when i remove oil cap the noise goes away .. ive got the crank shaft filter on order,, the engine light has come on,now(orange)is it ok to drive slowley for acouple of days? thanks mark
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
