2wd heat shield
The standard heat shield on a cosworth 2wd does that have to have brackets to mount to the car?
The reason i ask is mine came without a shield and i noticed one ages ago on ebay with brackets on the back.
I'm justabout to buy a new one bu needed to check this first.
Not got pics mate but just fitted one to my 3 door.
You'll need to basically bend a piece of metal 90 degrees and drill it and the bracket on the shield to bolt together and onto the inner wing, and the bolt fits the firewall bolt hole that's there from the factory.
I'm a spaz mechanically and managed it in about half an hour
Deffo get a heatshield - I melted some wires recently around thee turbo as my old one was shagged.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
cossie09
Sep 10, 2015 06:56 PM
