high revs
Old Jun 9, 2008 | 08:58 PM
RS SHAUN's Avatar
RS SHAUN
Default high revs
how do you set your cold idle, mine is far to high, ive checked icv and its working fine???
Old Jun 9, 2008 | 09:00 PM
rapidcossie's Avatar
rapidcossie
To set idle speed let the car come to operating temp then disconnect ISCV and use the screw under boost pipe on throttle body to set idle.
There is a lock nut on this screw.
Old Jun 10, 2008 | 02:31 AM
The above is how to set HOT idle, the raised COLD idle speed is controlled by the ecu/chip, mainly from the CTS reading, ie the colder it says the engine is the faster it will idle.
Old Jun 10, 2008 | 12:05 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Check you haven't got an air leak then .
Old Jun 10, 2008 | 03:22 PM
RS SHAUN's Avatar
RS SHAUN
many thanks lads
boeb
Jan 9, 2020 05:11 AM
Kam B
Sep 30, 2015 01:32 PM
