tremec box..
iirc mate there is some relocation to be done with the cradle depending on what car it is going in to.ive only seen them fitted to a few cars and most of them were only looked at briefly.
o ok mate.. its going on a 2wd saph.. dont really want to mess around tbh.. would of liked it to be bolt on and thats it
just made a call for you, there is a shit load of work involved and the guy i spoke to has fitted a few. if you want a number to call and chat with him PM me and i will send it you.
Basic mods to the bellhousing if you get the ford spec (get the close ratio one) tko one. Shifter is 10mm different to T5.
I have some more pics if you need - these are from Brom.
Paul got me a new tko 600 with release bearing for not much money (bout $4k aus but was a while ago) I can mod your bellhousing if you need.
Need new spline on clutch and prop shaft obviously.
Sender is electronic or mechanical - no prob for me as I have elec speedo - but maybe prob with standard speedo - don't know but i am sure would not be too much hasssle for a company called howard instruments for new speedo gears.
abdr500
Feb 10, 2009 11:26 PM
abdr500
Jul 29, 2007 10:24 PM
