closed loop
Old Jun 7, 2008 | 07:07 AM
raycov's Avatar
raycov
Thumbs up closed loop
who is running a l8 closed loop ecu on there s1 or s2 ,because i have just brought a l8 ecu with the loop fitted , i was wondering what else you need,i have been told you need tps off a 4 wd cossie, which i have, and then swap the 2 outer wires to the sensor around the other way. i also think you need a lambda ,ect,ect,i know on a cossie its a really good set up you just have to read the posts. any help would be much appriecated. i am running cossie managment with a l6 ecu.
cheers
Old Jun 7, 2008 | 07:29 PM
You will need a lambda, a wideband one for closed loop is best, if you are using a L6 wiring loom you do indeed swap the outer two wires over.
Old Jun 7, 2008 | 10:04 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
tabetha- please detail what L8 supports a wideband lambda sensor for closed-loop fuelling?
Old Jun 7, 2008 | 10:51 PM
DazC's Avatar
DazC
None of the Cossie ones.
Narrowband only.
Old Jun 7, 2008 | 10:57 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
That was kinda my point
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
pabloXR
Sep 21, 2015 12:42 PM
tib2220
Sep 14, 2015 12:33 PM
